OS: Windows 10
Version : 1.0.197
Downloaded the Joplin-Setup-1.0.197 from https://joplinapp.org/,
tried installing, went through the install process, showed an error, I hit ignore too fast. Now, I can’t install or open. So, tried to uninstall and install a second time, but it gives me the following message:
Windows cannot find ‘D:\Applications\Joplin\Uninstall Joplin.exe’. Make sure you typed the name correctly, and then try again.
