I noticed that Toggle Editor Layout only works for current note, would there be a configure for toggle Editor Layout for all notes? For example, if I toggle the preview mode for one note, when I click on other notes, it would also be in preview mode.
Thanks.
Are you using the beta Codemirror editor by chance? There was a bug that caused the layout to be reset sometimes while switching notes, but it will be fixed in the next release.
If this isn’t the case we’ll need more information to help you out, Could you copy and past the contents of Help -> About Joplin? And which Version of Joplin do you use (Windows, Mac, Linux, Windows portable)?
Oh, that’s true, I changed back to the old editor, it works.
Thanks for responding.
