Task management improvements
Love what you’ve created so far. Would like to see to-dos/tasks more tightly integrated.
  1. Automatically tag every to-do as to-do or task, so it appears in a list of tasks automatically.
  2. Select text in a note and turn into a task automatically and have it linked to the note for more data
  3. Use of a checkbox in a note turns it into a task with a to-do/task tag automatically
  4. Project tags to make it easy to categorize tasks into projects. I guess could be subtags similar to how Bear does tags #Project/Task
In addition, making due/reminder times visible and to-dos ordered by them, optionally.
I especially like #1 on your list. I’ve just discovered Joplin and am in the process of dumping all my Evernote content into it; if I could have a task list autogenerated as you describe (rather than having to manually tag every task – daunting since my Evernote tag list will take a long time to trim down), I could also dump my current task management app.
yes, i'm also hope to get items 2-4. Thats would be so useful in my workflow. Sorry for bringing this topic up. I just started exploring Joplin and it fits my needs so much. Maybe this features already covered by plugins. Could anyone give me to know if so?
I wish you team inspiration for further development)
Welcome @Dzenbo, I recommend checknig out various inline TODOs solutions that have been developed as plugins since this 2019 post.
  • Inline Todo: Generates summary notes with checkbox / TODO items from all your notes sorted by project / assignee tags.
  • Inline Tag Navigator: Displays inline TODOs in a panel (where you can also edit a task's status) or in a summary note, along with an advanced tagging and search system.
How checklists look on the panel:
Updating task state:
(EDIT: added screenshots)
Thank you very much for your answer. It helps me a lot!
