This is common on business-issued machines. Lots of places use a proxy (like a Barracuda or various cisco appliances) to intercept https traffic so they have visibility into employee usage and/or for data exfil protection, etc… For brevity in the reply, see, e.g., https://www.grc.com/fingerprints.htm . If you examine your browser or OS certificate store, you will most likely find a custom root cert so your browsers don’t throw an error on every https connection.
You can also test this yourself with openssl. You can see the whole certificate chain with this, think of it like tracert for certs.
$ echo -n | openssl s_client -connect content.dropboxapi.com:443
CONNECTED(00000004)
depth=2 C = US, O = DigiCert Inc, OU = www.digicert.com, CN = DigiCert High Assurance EV Root CA
verify return:1
depth=1 C = US, O = DigiCert Inc, OU = www.digicert.com, CN = DigiCert SHA2 High Assurance Server CA
verify return:1
depth=0 C = US, ST = California, L = San Francisco, O = "Dropbox, Inc", OU = Dropbox Ops, CN = content.dropboxapi.com
verify return:1
Certificate chain
0 s:C = US, ST = California, L = San Francisco, O = "Dropbox, Inc", OU = Dropbox Ops, CN = content.dropboxapi.com
i:C = US, O = DigiCert Inc, OU = www.digicert.com, CN = DigiCert SHA2 High Assurance Server CA
1 s:C = US, O = DigiCert Inc, OU = www.digicert.com, CN = DigiCert SHA2 High Assurance Server CA
i:C = US, O = DigiCert Inc, OU = www.digicert.com, CN = DigiCert High Assurance EV Root CA
Server certificate
-----BEGIN CERTIFICATE-----
..snipped..
-----END CERTIFICATE-----
subject=C = US, ST = California, L = San Francisco, O = "Dropbox, Inc", OU = Dropbox Ops, CN = content.dropboxapi.com
issuer=C = US, O = DigiCert Inc, OU = www.digicert.com, CN = DigiCert SHA2 High Assurance Server CA
No client certificate CA names sent
Peer signing digest: SHA256
Peer signature type: RSA-PSS
Server Temp Key: X25519, 253 bits
SSL handshake has read 3943 bytes and written 419 bytes
Verification: OK
New, TLSv1.2, Cipher is ECDHE-RSA-CHACHA20-POLY1305
Server public key is 2048 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
..snipped..
DONE
or
$ echo -n | openssl s_client -connect joplinapp.org:443
CONNECTED(00000004)
depth=2 O = Digital Signature Trust Co., CN = DST Root CA X3
verify return:1
depth=1 C = US, O = Let's Encrypt, CN = Let's Encrypt Authority X3
verify return:1
depth=0 CN = joplinapp.org
verify return:1
Certificate chain
0 s:CN = joplinapp.org
i:C = US, O = Let's Encrypt, CN = Let's Encrypt Authority X3
1 s:C = US, O = Let's Encrypt, CN = Let's Encrypt Authority X3
i:O = Digital Signature Trust Co., CN = DST Root CA X3
Server certificate
..snipped..
subject=CN = joplinapp.org
issuer=C = US, O = Let's Encrypt, CN = Let's Encrypt Authority X3
Peer signing digest: SHA512
SSL handshake has read 3206 bytes and written 418 bytes
Verification: OK
New, TLSv1.2, Cipher is ECDHE-RSA-AES128-GCM-SHA256
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
..snipped..
DONE
