Joplin 2.14.20 (prod, win32)
ID client : 49e8b5c0a27e4c7ea47133d561c692e5
Version de Synchro : 3
Version du profil : 46
Trousseau supporté : Oui
Révision : cfd98e3
Backup: 1.4.0
Favorites: 1.3.2
OneDrive
I suppose that it's not a problem but may be a reserved "word" for search...
I have a not called :
Unit Testing Dotnet (.NET) Application with xUnit .net & MOQ
When I use the global search and type all this text, the note is not found but as soon as I remove the ampersand, the global search found it, so with this text I can find the note :
So is this (the ampersand) a resevered word or a bug?
Bye
Try putting the whole thing is quotes
"Test1 & Test2"
Effectively, it runs !
Thank you very much.
system
Closed
4
