Hi there,
I am using the great plugin Simple Backup, with automated tasks.
But I found that the plugin does not runs the backups if Joplin is closed at the time.
Someone knows a way to run those backups even witth Joplin closed? Is there some kind of CLI app or interface for that?
Thanks in advance.
If you are trying to make sure that your backup is as up-to-date as possible (i.e. covering any changes between scheduled Simple Backups) all your other backup methods seem to be doing that job.
Alternatively run Joplin minimised on system startup.
Hum, that's true. Understood, thank you.
