Android
WebDAV
Have "Save geo-location with notes" enabled but no location info is saved. Precise location permission enabled.
If your app comes from F-Droid, then this functionality isn't available in that version. You need to use the official releases from Google Play or GitHub in order ot have it.
I'm using Obtainium pointed at GitHub - laurent22/joplin-android: Android releases for Joplin · GitHub . Using Graphine OS as well if that helps.
