Joplin version 1.0.147 (Prod, Linux)
Using manjao Linux
I noticed the sync is not working expected and wanted to dig a bit more into what’s going on. I found out some notes are not “leaving” my laptop machine and don’t get uploaded to OneDrive.
Looking at the log file I saw this.
FetchError: request to https://api.ipify.org/?format=json failed, reason: getaddrinfo ENOTFOUND api.ipify.org api.ipify.org:443
at ClientRequest. (/usr/share/joplin/resources/app/node_modules/node-fetch/index.js:133:11)
at ClientRequest.emit (events.js:182:13)
at TLSSocket.socketErrorListener (_http_client.js:391:9)
at TLSSocket.emit (events.js:182:13)
at emitErrorNT (internal/streams/destroy.js:82:8)
at emitErrorAndCloseNT (internal/streams/destroy.js:50:3)
at process._tickCallback (internal/process/next_tick.js:63:19)"
I have the geocoding option turned on under notes. trying this link on my browser showed it’s blocked by my university firewall.
I think some notes where this call to get their lat and long fails are not getting uploaded for some reason.
Wanted to report a bug, great work and thank you for the great application
