Hi...
I wanted to know if there is a way to delete data from lost android mobile device.
Unfortunately, I do not know the version of Joplin, as I have been using and updating it regularly and well.. my mobile device did not lose.
The app on the mobile device is in sync with the desktop software used on the laptop. Sync is through NextCloud.
Please share any working solution, if there is any.
This sounds doable.
But I still did not understand completely.
You meant to create another nextclud account by saying "you could also try to sync with Nextcloud from another app" ? Or I need to sync what? with which other app?
Please explain.
Hes just saying a way that you could cause a remote wipe.
Basically if you have another app (like the desktop app) and you delete all your data & sync then next time the mobile app tries to sync (i.e. if somebody opens it) then it will start deleting everything on it.
Obviously you would want to make sure all of your data is backed up before you did that and you would want to make a new folder on your nextcloud so that the original app can no longer access it if you wanted to sync devices again.
Thanks mate. This is done. This method was easier than I thought.
Any one else having issues understanding what @laurent said like me.. please check the other marked solution.
