I am not sure what you mean? Maybe RichText rather than markdown?
Do you mean links to notebooks? I think there's no support in Joplin for such links atm. "Copy external link" may work from within Joplin though I'm not completely sure.
I apologize, I'm still confused about the naming. Your plugin works in WYSIWYG, but it wasn't working in RichText, right? If so, I meant RichText.
Yes! You know these matters better. Is it technically challenging to provide support for this?
Regards...
I think it's one of those things where there's no way to know until you start. But it can be done I'm sure, I personally just don't have time for it now.
Sure. Whenever you have time, maybe you'd like to consider it. Thanks a lot for your great work so far. I'll be looking forward to new ones as your follower.
While the "Note Link System" plugin stopped working partially, i came back to your original Quick Link. Note Link System had an enhanced quick link feature: full text search results available in drop down like when you hit cmd+p. That was so handy, maybe an idea for an possible update (maybe even as an option in the settings!?)!? Thanks for the plugin!
Here's my ideal setup as well as an explanation for anyone coming here after the "Note Link System" plugin:
Hi, everyone
I've updated the “Quick Links” plugin using Claude Opus 4.8 so that it supports CodeMirror 6 (recent versions of Joplin).
See my post:
