I am running Joplin 1.8.5 on both Windows 10 and Ubuntu.
The underline shortcut (Ctrl + U) does not appear in the "Keyboard Shortcuts" menu.
However, in the WYSWYG editor, when I select a word / sentence and press Ctrl + U, Joplin underlines the text, as expected. Problem is that when I close the note and open it again, the text is not underlined anymore, as if the change had not been saved.
If I underline the text by clicking on the corresponding button
, I do not face this problem (changes are saved properly). Other formatting keyboard shortcuts (bold, italic, etc.) seem to work fine as well.
Is this a bug, or something I can fix in the settings ?
Thank you for your help !
