Type “ABC” in the comment. If the double quotes are Chinese punctuation marks, the cursor display will be misplaced and the cursor cannot be moved to the end of the text.
OS:Windows
OS:Windows
Can someone help me see what’s wrong? Or is there a similar problem? Thank you
You need to use a monospace font in the editor (you can chance in the settings).
thanks for your help
Can you please help me see another question
