Help: The problem occurs when there are 3 spaces at the beginning of the paragraph
Question for help: When there are more than 3 spaces at the beginning of the paragraph, when the text exceeds one line, the cursor will be misplaced and the character at the end of the paragraph cannot be selected. Thank you
os:windows
Please help verify this problem and see if there is a solution, thank you
I can’t reproduce this issue on my computer. Usually these errors happen when the editor font is not a monospace font. What do you have set in the Editor font family field?
Here is an example from my computer.
I set the language to English and I can reproduce the problem
1、There are more than 3 spaces at the beginning of the paragraph
2、Please enter more characters. It is normal when there is only one line. If more than one line, the cursor will be misplaced and the end of the text cannot be selected.
thank you
Please try with a different monospace font as it’s most likely a problem with your font. I can’t replicate it:
Thanks, I will try more
Hello, the problem is solved after changing to the “courier new” font, but the right-most interface cannot be displayed on a new line. Can you please help. Thank you
When there are only three spaces at the beginning of the paragraph, the display on the right is normal
When there are more than 4 spaces at the beginning of the paragraph, only one line is displayed on the right
