Hi
This plugin is excellent, thanks a lot @benlau ![]()
Quick question, is it possible to add tags to favorites? I tried drag and drop and it doesn't work.
Hi
It is glad to hear that you like the plugin. For your feature requests
Drag a shortcut into a new tab to open the shortcut in a new tab
I never used the note tab plugin, what if you drag a link from recent notes, can it open a new tab?
If yes, then it should be the same issue like this request, I would try to make it on next release.
Drag a note from a tab of the "note tab" plugin to the shortcut panel
"Control + click" on shortcut/recent to open the wanted link in a new tab
It depends on the implementation of note tab. Need to check it source code to confirm it.
Add the currently edited note into the shortcut panel via "Command Panel"
What is the usecase..?
CSS customization
hmm.. any example of Joplin plugin that support CSS customization?
And then...
sorry, I don't quite get what you mean.
Hey, where can you drag a tag ? I just thought the tag in Joplin UI is not draggable.
1.
Yes, indeed, recent notes can be dragged into a new tab, while shortcuts cannot. So it's basically the same request as what you linked before.
2.
Instead of dragging a note from the note side panel into the DDDot shortcut panel to create a shortcut, it would be great if I could add a shortcut while the side panels are collapsed. So the procedure would be:
Or even simpler than that? Just create a keyboard shortcut?
3.
The plugin Note list Preview allows some CSS customization via the userchrome.css file. Although maybe that is because it does not use a dedicated panel?
Wouldn't it be possible to add a CSS field in the plugin settings options, so that the user can add some custom styling? What I'd love to achieve is something that looks like this, if possible, I'd also change all the hamburger icons with some FontAwesome's icons too:
The screenshot above was styled via the following code, but it only works in the Developer Tools, not via userchrome.css unfortunately:
/* DDDot - main background */
div#dddot-panel-container {
background-color: #020e21 !important;
/* DDDot - title of sub panels */
.dddot-tool-header {
color: #9fdaff !important;
/* DDDot - Items colour */
.dddot-note-item a {
font-size:14.8px !important;
color: #ffffff !important;
/* DDDot - Scratchpad */
.CodeMirror.cm-s-blackboard.CodeMirror-wrap {
color: #00ffef !important;
border: solid !important;
border-width: 2px !important;
border-radius: 9px !important;
border-color: #00e2ff47 !important;
4.
Then regarding the sync stats... it would be nice if I could see if the synchronization is working fine when I have the main side panels collapsed
And then...
Full view:
From this screen, I would like to be able to create a new shortcut without needing to open the Joplin side panels, hence the request to drag and drop, and the Comand Panel request of point N.2 (above).
You're right, drag and drop doesn't work at all ![]()
Is there a solution to add tags to DDDot shortcuts?
And a few other questions:
Do the links created in Outline only work if the DDDot plugin is installed or are these links that can work with basic Joplin?
Would it be possible to add a line break? (especially in the Outline section but everywhere would be even better). Example of line break with another Outline plugin (on the left DDDot, on the right Outline plugin):
Ideally, there would be an option to enable it or not, depending on the needs.
In case of no line wrapping, it would be handy to have all the text displayed on mouseover.
Would it be possible to have an Internal Links section? : a section that displays the internal links of the note.
Thanks ![]()
Should be doable.
Thx. Let's me take a look first. I guess I need to refactor a few css rules
I see. If that is implemented, it should be a tool which could be turn on/off by user.
Currently, it is not implemented as dragging a tag is not possible. Therefore, I hadn't planned to include it. However, I am considering adding a button that would display a dialog for users to manually enter the tag name.
It works with basic joplin without this plugin
line break
Adding line breaks or word wrap could be possible, but it might be included in a release after the next.
Could you explain the use-cases?
Thanks for the first 3 points ![]()
If I have an A note that contains links to B, C, D E... notes, have a section that displays these links.
It takes approximately 7 seconds to open random note after I clicked the button, is that normal?
It is abnormal. What is your Joplin version and operating system?
How many note you have? (It may be quite troublesome to count. Let's change the question. I have around 7,000 notes, but it still completes quickly. Do you think you have more notes than that number?)
Hi there,
I have approximate 27000 notes. Below is the data for version stuff.
Joplin 3.2.8 (prod, win32)
Client ID: 95129a039d73425ca166bc4a948de767
Revision: d458648
Backup: 1.4.2
Joplin DDDot: 0.4.2
Note Tabs: 1.4.0
Wow...
Could you try this version and check if it is faster?
publish/joplin-plugin-dddot.jpl and install it via Joplin > Settings > Plugin.This version caches the information for 5 minutes. The first call may have a delay, but subsequent calls should show the result instantly.
I will see what I can do, thanks for the works. This plugin does help!
To @JackGruber
BTW, the method as above quote did not work anymore, the original thread was closed, so I mention this here. Speaking of closing a thread, I would like to rais awareness of the issue as below:
Daily Note
Random Note
Scratchpad
Outline
joplin.clipboard.writeText()).Shortcuts
Recent Notes → Shortcuts).Localization
zh_CN) translation.fr_FR and zh_TW translations with more complete UI coverage.Just stumbled upon this plugin as I was searching one that would handle backlinks correctly. Happy to say that this one works perfectly in that regards, even on emails-to-notes
I love the outline section, once I figured out what it meant LOL and the shortcuts are VERY handy while working on a bigger project.
I have one request: the DDDot panel is too wide for my use (and my laptop) and I resize it. But unfortunately that resize is lost after toggling sidebar, notelist or the DDDot Visibility. When I toggle the sidebar for instance, its width remains the same set width when visible. Would it be possible to have that for the DDDot panel?
Also a quick question: what does "Include URL with schemas (',' separated, e.g. http,https,file)" mean in the Options section of DDDot Plugin?
Finding this plugin made my day ![]()
The size not persisting is a joplin limitation that impacts any plugin panel: Panel width for plugins do not persist · Issue #5634 · laurent22/joplin · GitHub
Thanks! Cool feature!
Hi there,
Since the Outline plugin I had been using stopped working properly with Joplin 3.5.11 and is apparently no longer being maintained, I came across DDDOT and am very happy with it!
The Recent Notes feature is a great idea and I use it often (Outline couldn't do that).
Nevertheless, I have three small suggestions for improvement to make DDDOT perfect in my opinion:
Thank you in advance!
Workaholic ![]()
