Plugin: 🎨 macOS theme for Joplin
Ah yes, I actually never tried that. This should be fixed in the new version!:
Awesome! Fixed! Thank you so much :smiley:
Hi @andrejilderda! First of all, I want to thank you for the wonderful work that makes Joplin look like MacOS.
I have a question about displaying an emoji next to the tag name. In the native Joplin theme, emoji insertion allows you to remove the tag icon, which is not the case in macOS theme. I described this issue on Github.
Perhaps there are some custom style settings that can be applied or will you fix this in future updates?
Regards.
How can i have the joplin default line between Heading an text in a standard note. With the normal joplin there is a line
A very simple way is to put these lines into the userstyle.css (Tools -> Options -> Appearance -> Advanced Settings -> CSS for rendered Markdown):
h1 {
    border-bottom: 1px solid #dddddd !important; /* light theme */
    /* border-bottom: 1px solid #555555 !important; */ /* dark theme */
    /* border-bottom: 1px solid #eee8d5 !important; */ /* solarised light theme */
    /* border-bottom: 1px solid #586e75 !important; */ /* solarized dark theme */
    /* border-bottom: 1px solid #bd93f9 !important; */ /* dracula theme */
    /* border-bottom: 1px solid #5e81ac !important; */ /* nord theme */
    /* border-bottom: 1px solid #141a21 !important; */ /* aritim theme */
    /* border-bottom: 1px solid #3D444E !important; */ /* OLED theme */
If you are using a different theme then the default light one, comment the light one and uncomment the right one for the general joplin theme you are using (/* marks the beginning of a comment, */ its ending).
Seems to be the version are not compatible, in the use of plug-in can lead to take up a lot of CPU, show white, can't operate joplin
joplin windows:v2.9.17
macos-theme:v1.3.11
Here it is still working fine, but I'm on a mac M1 Max.
You're not the only one who has mentioned degrading performance. I'm surprised that this plugin - which is doing very little other than appending CSS - can cause so much trouble. Tbh, I think there's a bigger issue with the plugin system, which is why I won't try to fix this issue (and spend my time on Desktop UI in stead ;)).
The macOS plugin is bricking my Joplin on both Arch Linux and Windows 11 to the point that I cannot even operate the menus. In order to disable the MacOS plugin I have to force-quit joplin and open the options menu before the macOS plugin is fully loaded.
The macOS theme plugin removes the scrollbar in the Go to window.
See Searching for phrases - #8 by laurent .
This should be fixed with the latest update of the plugin.
Thanks for the bug fix. But I don't see any changes:
macOS Ventura 13.2, M1, Joplin latest release version.
Update worked successfully for me. I am re-enabling the plugin and will report back if I experience crashes again.
v1.3.12 is the version that I was referring to, but v1.3.13 is on its way with a small tweak.
The problem is back. I can reliably reproduce it when clicking on the sidebar to expand a parent notebook to show child notebooks. Each of my notebooks has a leading emoji if that is significant.
@andrejilderda, it appears that your plugin is crushing joplin during update from 2.10.17 to either 2.10.18 or 2.10.19 - please see my post here: Joplin 2.10.18 does not open after update from 2.10.17 - #4 by bre
I accidentally installed the plugin on windows application and after restart the app crashed. Can you please help me resolve the issue?
@linliiq32 welcome to the forum.
If you mean that after installing the plugin Joplin crashed and continues to crash every time you start it, one thing to try first is to:
Ensure that Joplin is fully quit (i.e. not running at all). Then go to...
C:\Users\<username>\.config\joplin-desktop\plugins (where <username> is your account username)
and delete...
com.andrejilderda.macOSTheme@1.3.13.jpl (or whatever version you have installed)
Then restart Joplin.
This is a really awesome plugin. I'm not particularly pro-mac, but this is IMHO how Joplin should look out of the box.
I would love an easy way to change the base font types and sizes from the GUI though. I realize there are ways to hack it through the config files, but we are not all programmers used to deal with style sheets.
Experienced the following issue, which goes away when I disable the macOS theme plugin (v1.3.13): Anyone else have a grey vertical bar at left edge of the MD editor?
Specifically, it seems like it might be a conflict between macOS Theme plugin and Folding in Code Mirror Editor plugin:
Added issue to github: grey vertical bar at left edge of the MD editor when both macOS theme and Folding in Code Mirror Editor plugins are enabled · Issue #108 · andrejilderda/joplin-macos-native-theme · GitHub
Thank you for the awesome theme!
I'm on Windows 11, and the last 4 toolbar icons are blank for me. (Horizontal line, Blockquote, Table, Insert time). I have Joplin 2.13.9 and installed the macOS theme plugin version 1.3.13 from inside Joplin. I have the icon family set to Phosphor. Am I doing something wrong to cause those icons not to appear?
Thanks!
