This should be fixed in the latest version (v.1.3.14). Enjoy!
Looks good, thanks!
I love your macOS theme for Joplin, it looks awesome!
The only thing I just noticed:
When I enable the new note list preview plugin, the layout and typography of the note list plugin look very inconsistent with the MacOS theme.
Would it be possible to adjust the MacOS theme plugin so it supports the new note list preview layout and everything looks consistent?
I don't plan on adding support for the plugin mentioned, but am open to PR's!
Thanks so much for the theme! It looks gorgeous. ![]()
My only gripe is that in the markdown rendering on light mode, lists are somewhat hard to read. I'm usually not super big on over the top contrasts, but the default is just not working for me. I solved it with this CSS code in my user styles (if anybody else is running into the same issue):
body .CodeMirror.CodeMirror.CodeMirror span.cm-variable-2 { color: #32373F !important; }
If anybody is interested in my other custom styles (just minor tweaks, nothing specific for this cool theme), here they are:
h1 { margin-top: 45px !important; }
ul + *, * + table { margin-top: 30px !important; }
hr { margin: 30px 0 !important; }
ul li.md-checkbox label.checkbox-label-checked { text-decoration: line-through !important; }
Thanks again and keep up the good work. ![]()
Hi there!
I have the same issue that redsteadz and benmordecai had - I don't see any icons. And when I try adding new ones, the app crashes :((
I use Linux (Ubuntu 22.04), the newest possible Joplin version 3.0.6 and your plugin version is 1.3.18
I loooove this plugin, but it hurts my eyes, when there are this strange, crossed out squares instead of cool icons! Could you please help me? Thanks
Okay, so it looks like the problem was in Joplin's version. On 2.14.20 folder's icons works just fine. I can't still change them though. The app always crashes. Probably because this version is too old? Ehh... I can live with that :') Thanks for your amazing job!
@saurinko Does the crashing still ocur for you on Joplin 3.0.6 with the latest version of the plugin (v.1.5.2)?
Hi! I'm sorry it took me so long to reply. I've just checked it. So, yeah it still doesn't work on Joplin v.3.0.6 with the plugin version 1.5.7 - that's currently the lastest. I still can't change the icons, otherwise the app will crash.
Hi there! Theme looks awesome! Just one question though - is it possible to have grey strikethrough text on a checklist item when it's checked?
I have added your issue to the Github issue list here. ![]()
I just installed this plugin and now Joplin hangs on launch and eventually I get a "Window unresponsive" dialog with the options to Ignore, Restart in safe mode, or Force quit. If I disable the plugin once in safe mode, I can restart and Joplin will launch as normal. Is this a known issue?
[UPDATE: every time this happens, a crash log is saved in my home directory. However, I just tried it again and now the dialog isn't appearing and I have no way of disabling the plugin. Is there a way to force safe mode on launch?]
I don't know if you solved this, but I found that many of my plugins were incompatible with macOS Theme and would cause the hang-on-launch problem. Once I started down the road of disabling all plugins except macOS Theme and then reenabling other plugins one-by-one, and finding multiple incompatibilities, I gave up and disabled macOS Theme.
Yes, some users have issues with Joplin freezing on startup with this theme enabled. It seems to be related to the folder emoji's. This is only an issue for some users and unfortunately (
) I'm not one of them, so unable to fix this. However, there is this workaround.
Hello and thank you for the great job.
I'm here to report an issue: after installing the plugin "macOS theme" (v1.5.14) in Joplin (3.2.13) on macOS 15.3.2, every thing looks fine until I click on any notebook. Then Joplin freezes. If I disable only this plugin, then everything is back to normal. I tried to check if it conflicts with other plugins but couldn't find anything relevant.
Yes, a few people reported before and it seems related to the emoji folder icons. You can try the workaround here:
It works
thank you ![]()
You can by adding this line to userstyle.css (which you can open via Settings › Appearance › Show Advanced Settings › click "Custom stylesheet for rendered Markdown").
li.checked {
text-decoration: line-through;
/* Optionally set the strikethrough color*/
/* text-decoration-color: black; */
Pretty late to the party on this - loving this plugin!
Not sure if possible but could this be added either as an official theme (i.e. inbuilt) or enabled for the iOS/iPadOS clients?
me too
