Plugin: inline tags
Hello. I downloaded your plugin and left a comment. Thanks a lot for sharing. By the way, I have some topics that I opened for the issues I encountered in Joplin, and unfortunately, they haven't received much attention. I would like to invite you and all valuable Joplin users to my topics:
Hi. Is there a way to get this wonderful plugin to work with the Rich Text Editor? I'd love to use inline tags but I only really use the RTE and it doesn't seem to do anything there.
Many thanks
Ben
Not at the moment. I am not even sure it can be done at all.
That's a shame but no worries, I understand. Thanks - I appreciate your reply.
This plugin need a lot of work. It doesn't find already created tags and wants to re-create already existing ones. It doesn't show every tag not sure how it's choosing which ones to show and the ones that do show are in some weird crazy order so when you have a lot of tags like I do there is no way to find the one you're looking for as their not in any recognizable order, not In alphabetical order, they're all mish-moshed together and you have to look up and down forever or read each and every one to make sure you don't miss one as you go down the line that that could be the one you needed! I have no choice but to uninstall for now as it is currently unusable in its current state. Thank you.
The plugin is really great but I agree that it would be more convenient to have the autocompletion feature available also for tags already on the note, or to have an option in the parameters to enable or disable the feature.
Thanks !
Not support Chinese :frowning:
