i left using it. I am using built-in shortcut for tags.
When you enter "#" in editor, inline tag's pop-up comes out.. It could be a header why popup comes out? So popup should only be opened "if a letter comes after #, if there is space it shouldn't show up" you can handle this statement, i know.
Simplely put, do i have to see an unrelated pop-up when i have an intention to write header? Even if that pop-up would go away after hitting the space bar.
That popup should only appear if a char comes just after it. That is my suggestion.
The reason for showing the popup immediately without waiting for the 1st symbol is that it can show you all your tags whereas in the other case if you typed, say, #a it'd only show the tags starting with "a". I can easily imagine a situation where you don't know the exact tag name and need to look at the list to pick.
Because of this and the fact that you're the first to complain about this behaviour, I'm going to keep the logic as it now, sorry.
Thank you for your feedback about popup, i respect but since i use headings more and it distracts me, i wouldn't use it. What do you think to implementing of Hierarchical Tags? Is it possible in Joplin?
It is certainly possible. There even was an attempt to do this but it had to be reverted because of performance impact.
I'm sure it will be done eventually.
First of all @roman_r_m , thank you very much for this plugin : it's a simple, easy to use but yet powerful plugin, that completely change the way of using Joplin ! It makes tagging so much easier and really enhance Joplin's usefulness.
However, your plugin seems to be case sensitive, when, imho, it shouldn't : if I type "#something", it won't find "#Something" in the tag list. Also it won't add the tag to the note in this case.
Great idea, but... it seems that the use of (#) interferes with markdown language. Since I installed the plugin I haven't been able to use hashtags for titles ands subtittles, so, unless there is a fix for this (or maybe I'm doing something wrong), I will have to uninstall
Hi @roman_r_m , thanks a lot this plugin! I was going to search how to implement tags by typing into the text body of a note. But before I really started searching I stumbled over your plugin. it's simple, easy to use and very convenient to me!
There is only one thing I would like to suggest: please reconsider the capital letter sensitivity. I am one of the migrants from Evernote and have tags with capital initial letters. So the plugin never offers me the "old" tags with capital letters when I - as usual - start typing with a lower case letter. And of course the reverse is also true when I start with an uppercase letter for all lowercase tags.
Thanks for the plugin and thanks for reconsidering!!!
Hello. What are the advantages of writing tags within the text? What benefits does this plugin provide? I have about 300 tags. It would be nice to understand the logic behind it if it's functional.
You can do some additional things with inline tags using this recent plugin. The two plugins (the awesome one in this thread and the one linked) can be used together, of course.
