Multi level check lists
Joplin 1.7.11 (prod, linux)
Client ID: ff9d85bc8da84f048eaaa80d703bfa72
Sync Version: 2
Profile Version: 34
Keychain Supported: No
Revision: f560563 (master)
I have a check list that has 3 levels. A couple things I'd like to do that I don't see a way to do unless I'm missing something. I'd appreciate any thoughts.
First is, I'd like to be able to collapse the children so only the parents are visible.
Second, I'd like to see the parent automatically be checked when all of the children are completed.
Does anyone know if there are any plugins or any other way to accomplish this?
Thanks
In a one note ?
I guess I don't really understand the question, but yes in one note.
level 1
level 2
level 2
level 3
etc.
Sorry looks like it didn't keep the indentation, but the different levels should be indented.
It may not be what you wanted, but there is a plugin for heading folding.
Thanks very much, I'll take a look at it.
edit: Thanks, I took a look. It's partially what I need but doesn't really work as it only folds actually headers designated by one or more "#".
I do appreciate the response
