In the native client, no external editor. I never see it happening so yes it seems to happen when syncing. My last paragraph is okay, what I typed yesterday has decreased indents to initial (0) level.
It’s not about rendering, when typing it everything is okay. It’s later when I get back to editing it, then the list levels have resetted. So maybe something on syncing.
I've also trying to reproduce this without success (although I'm on macOS). My lists are still all fine. I've never experienced anything like this.
Do you have a cat? Or a poltergeist?
The only explanation I could think of is that you opened the note with an external editor, but never stopped watching it. Then for some reason the editor autosaves and trims all leading whitespace characters. (Without you noticing.)
No I assure you, my home has been ghost-free for the past years since I invited an exorcist all seemed well? I thought so at least! hehehehe XD Kidding aside, there’s nothing you listed that I’ve done or have been happening here lately.
I use Nextcloud to sync everything, I’ll try to check if something else than Joplin tampers with the note files. I never even opened any notes in an external editor yet. There must be /something/ but I really don’t know what.
Haven’t been happening this past weekend, I’ll update the thread if I find out any more details.
Are you able to run SQL dump of this particular note when it’s fine and when corrupted?
To see whether the spaces disappeared in raw note? (Slightly high-level troubleshooting)
It just happened twice today, this is exactly what I did: I added a few items to my list, switch note, tweaked another list, switched back and what I typed was on the same level. Just tried to replicate it repeatedly without any success I really wonder what's up with that. (FYI: notes from the same notebook)
I will try to provide SQL dumps as required, it’s the first time it is infinitely reproducible so I’m kind of excited to finally have a way to demo it since it’s SO annoying!
LOL thanks for such a good helpful reply! I know how to play with sqlite databases.
I just don't know which exact table and how to fetch that specific note within Joplin's DB structure.
I'll figure it out on my own
I stopped using the CTRL+SUPER+PageUp/PageDown and only use SUPER+PageUp/Down and now it doesn’t happen anymore. I’m SO HAPPY! There was interferences between my i3wm bindings and Joplin’s
