Hello
I have a joplin instance on my personal server, it's running with Docker.
I can't connect through web interface because I have lost password for my 2 account (admin and mine). I still can use joplin with my phone and my computer with android app and the portable application.
I want to use the option to sent recovery password by email but when it's configured, logs told me mailer config is disabled.
Here what I have set :
docker-compose.yml :
app:
image: joplin/server:2.14.1-beta
depends_on:
- db
ports:
- "22300:22300"
restart: unless-stopped
environment:
- APP_PORT=22300
- APP_BASE_URL=${APP_BASE_URL}
- DB_CLIENT=pg
- POSTGRES_PASSWORD=${POSTGRES_PASSWORD}
- POSTGRES_DATABASE=${POSTGRES_DATABASE}
- POSTGRES_USER=${POSTGRES_USER}
- POSTGRES_PORT=${POSTGRES_PORT}
- POSTGRES_HOST=db
- MAILER_ENABLED=${MAILER_ENABLED}
- MAILER_HOST=${MAILER_HOST}
- MAILER_PORT=${MAILER_PORT}
- MAILER_SECURITY=${MAILER_SECURITY}
- MAILER_AUTH_USER=${MAILER_AUTH_USER}
- MAILER_AUTH_PASSWORD=${MAILER_AUTH_PASSWORD}
- MAILER_NOREPLY_NAME=${MAILER_NOREPLY_NAME}
- MAILER_NOREPLY_EMAIL=${MAILER_NOREPLY_EMAIL}
The .env file :
APP_BASE_URL=https://joplin.fqdn.com
APP_PORT=22300
DB_CLIENT=pg
POSTGRES_PASSWORD=password
POSTGRES_DATABASE=joplin
POSTGRES_USER=joplin
POSTGRES_PORT=5432
MAILER_ENABLED=1
MAILER_HOST=mail.server.com
MAILER_PORT=465
MAILER_SECURITY=ssl
MAILER_AUTH_USER=mail@fqdn.com
MAILER_AUTH_PASSWORD=password
MAILER_NOREPLY_NAME=joplinserver
MAILER_NOREPLY_EMAIL=no-reply@fqdn.com
Logs :
app_1 | 21:25:00 0|app | enabled: false,
app_1 | 21:25:00 0|app | host: '',
app_1 | 21:25:00 0|app | port: 465,
app_1 | 21:25:00 0|app | security: 'tls',
app_1 | 21:25:00 0|app | authUser: '',
app_1 | 21:25:00 0|app | authPassword: '********',
app_1 | 21:25:00 0|app | noReplyName: '',
app_1 | 21:25:00 0|app | noReplyEmail: ''
app_1 | 21:25:00 0|app | }
app_1 | 21:25:01 0|app | 2024-02-14 21:25:01: EmailService: Service will be disabled because mailer config is not set or is explicitly disabled
Does the settings are correct ?
Thank you for your help.
system
Closed
2
