Mailer settings
Regarding Mailer settings
all is correct, but the docker-compose.yml has to be enriched with
          restart: unless-stopped
+         env_file:
+             - .env
         environment:
Otherwise the environment variables are not taken into account.
But another thing is unclear.
How can I configure it to novalidate-certs, or using starttls?
I needed to run the mailer on port 465, having tls, but was not allowed to just put in an IP Address.
app-1  | 16:28:01 0|app  | 2024-12-26 16:28:01: [error] EmailService: Could not run maintenance: Error: Hostname/IP does not match certificate's altnames: IP: 172.17.0.1 is not in the cert's list:
app-1  | 16:28:01 0|app  |     at new NodeError (node:internal/errors:405:5)
app-1  | 16:28:01 0|app  |     at Object.checkServerIdentity (node:tls:337:12)
app-1  | 16:28:01 0|app  |     at TLSSocket.onConnectSecure (node:_tls_wrap:1669:27)
app-1  | 16:28:01 0|app  |     at TLSSocket.emit (node:events:517:28)
app-1  | 16:28:01 0|app  |     at TLSSocket._finishInit (node:_tls_wrap:1070:8)
app-1  | 16:28:01 0|app  |     at TLSWrap.ssl.onhandshakedone (node:_tls_wrap:856:12) {
app-1  | 16:28:01 0|app  |   reason: "IP: 172.17.0.1 is not in the cert's list: ",
app-1  | 16:28:01 0|app  |   host: '172.17.0.1',
app-1  | 16:28:01 0|app  |   cert: {
app-1  | 16:28:01 0|app  |     subject: [Object: null prototype] { CN: 'mailer.com' },
app-1  | 16:28:01 0|app  |     issuer: [Object: null prototype] { C: 'US', O: "Let's Encrypt", CN: 'E5' },
app-1  | 16:28:01 0|app  |     subjectaltname: 'DNS:joplin.mailer.com, DNS:mailer.com',
app-1  | 16:28:01 0|app  |     infoAccess: [Object: null prototype] {
app-1  | 16:28:01 0|app  |       issuerCertificate: [Object]
app-1  | 16:28:01 0|app  |     }
app-1  | 16:28:01 0|app  |   },
app-1  | 16:28:01 0|app  |   code: 'ESOCKET',
app-1  | 16:28:01 0|app  |   command: 'CONN'
I'm facing exactly the same issue. I'm using .env file, all app and db variables are being applied but MAILER_.
I tried docker exec -it bash and when export I can see all of the variables set in docker-compose.yml and .env but those MAILER_.
Then seeing excatly the same message in the log.
Running Joplin server 3.0.1.
