Local links no longer work (unless linkify is turned on)
After dragging and dropping while holding the option key to create a reference a link is properly created, like so:
[bla.pdf](file:///Users/tessus/Downloads/bla.pdf)
However, the preview window shows it exactly as above and not as a link.
When I turn on Linkify in Preferences -> Markdown, the link is shown properly:
IMO this has nothing to do with linkify and looks like a regression to me.
Joplin 1.6.1 (dev, darwin)
Client ID: e354a932e6e143c782264aad4112b674
Sync Version: 2
Profile Version: 34
Revision: 694a1b4ed (dev)
Yes there was indeed some issues with validating URLs, which will be fixed from next release.
Yep, fixed in:
Thanks.
