To report a bug, please let us know:
The version you are using. LATEST VERSION is not a version number!
1.0.327 -
If you report a problem with upgrading, please let us know both versions (from/to).
The operating system you are using.
Android 10 (Samsung Galaxy Note 10)
This is the new issue I observed since I upgraded my phone from Samsung Galaxy S8+ running Android 9 to Samsung Galaxy Note 10 running Android 10.
Here is the working setup when I was on Samsung Galaxy S8+. On my PC I setup the Joplin Desktop to sync to a local folder, say Notes. Then I sync it with /storage/emulated/0/Notes on my Phone with Syncthing. Then in Joplin Mobile I let it sync to /storage/emulated/0/Notes.
But the same exact setup failed on Galaxy Note 10. What I notice is that Joplin Mobile is read/write from /storage/emulated/0/Notes but that folder is NOT the same folder as the one synced from PC. In another word, I saw two exact same folder Notes under path /storage/emulated/0/ which is really weird.
Can someone please help me with explaining this behavior and any direction on how to address this. Thx
