Hello team,
my version is
joplin 2.0.1 (prod)
terminal version.
sync
Synchronization target: File system (2)
Starting synchronization...
Completed: 17/06/2021 00:14
Missing required argument: note
Issue: I try to sync my terminal Jolin with my local nas as FileServer that I got configured trough NFS.
I've being looking for documentation about hot to set
:config sync.target 2, I realized option 2 because it said no option1 exist and then shown the options.
I followed this official Synchronization Documentation from https://joplinapp.org/ .
Could you please let me know which parameter is required I guess is something like
:config sync.2.note something.
Thank you in advance,
Serguei Esquivel
thank you for quick response,
:config sync.2.path /home/user/mnt/joplincenter
I double checked permissions and could create modify and delete files in that path, but still having message Missing required argument.
regards,
Serguei
Does anybody has documentation about each parameter of sync class?
thanks in advance,
Serguei
This is strange, sync
does not require note as an argument.
Can you post step by step what were you doing, each command and the corresponding output.
This is step by step
config sync.2.path ~/General/unidocs/docAdminSES/joplincenter
sync [Press Ctrl+C to cancel]: Completed: 17/06/2021 11:02 Last error: Error: Error: Could
another important thing maybe root cause is Freebsd13.
please let me know any idea.
Not sure why you're getting this error - I've just tried it and it worked for me.
Maybe try exporting your notes, deleting the profile, and start over.
system
closed
18 July 2021 17:22
#9
