I wanted to share an idea on how to use direct links from the reference given in Joplin to the entry in the zotero library.
This follow the question raised in comment 17 of the main topic BibTeX Plugin.
Background
Each item in zotero has it's own ITEMKEY, both the entry in zotero and the attached e.g. pdf file.
The reference given in Joplin could link to one of these items by using the local zotero call via zotero: or using the webpage of the user.
1. Open pdf file of reference.
- The ITEMKEY of the local pdf file can be found in the "file" key in the .bib entries.
file = {path/to/dir/ITEMKEY/filename} - This could be used in combination with
zotero://open-pdf/library/items/ITEMKEYto open the pdf directly in zotero.
2. Highlight entry in the zotero bibliography
- The .bib file does not contain any information on the entries ITEMKEY.
- Note: it is different from the file ITEMKEY!
- In the BBT zotero extension one can add a postscript to store the information of the ITEMKEY of the entry (not the related pdf-file) "if (Translator.BetterTeX) reference.add({ name: 'key', value: item.itemKey })"
Using this new 'key' in the .bib file entries would create:key = {ITEMKEY}. - In combination with
zotero://select/library/items/ITEMKEYown can create a link to highlight the zotero item.
This could also be a weblink, if one uses zotero websync.
The ITEMKEY needs to correspond to the 2. option given above.
The webadresse would be https://www.zotero.org/username/items/ITEMKEY/library
So that the user would need to provide his or her username in the preferences of the plugin.
