Jumpy and slow (not smooth) scrolling after editing a long note
If you are not sure if it's a bug or not, PLEASE POST ON GITHUB ANYWAY.
If you can also please provide a log, as described here: How to enable debugging | Joplin
Joplin 2.9.17 (prod, darwin)
MacOS 13.2.1 (22D68)
After editing a longish note, I found that scrolling stops being smooth and becomes "jumpy" in fact one swipe on the trackpad up or down creates continuous scrolling for a long time sometimes.
This happens all the time.
Quitting and re-starting Joplin solves the problem.
How can I fix this?
