gri38
41
You're probably right. I don't really know difference between katex and latex...
Indeed I used katex library... I will update the readme: if it doesn't speak to me, it will speak to those who use it.
It seems katex is just the js library to render latex. Si finally, the product renders latex, user doesn't really care it's done with katex? Don't you think @MrKanister ?
But I renamed to KaTeX: maybe it deosn't handle the full LaTeX language...
Katex as I understand is a subset of Latex, used to render math formulas only. Currently Joplin indeed doesn't support the full Latex language.
Yes, it doesn't handle the full LaTeX syntax...maybe this article helps?
gri38
44
Hello.
I communicate on a bug fix which was quite impacting (at least for me and my data):
I fixed bug when attachment is too large, note edition silently fails.
Released on v2.2.2.
Great work! Just to be clear, you need to have nginx running on the same vm/pc if you want to use the docker-compose-joplin-only.yml file? I have nginx running on another vm and can't seem to get joplin-vieweb running.
gri38
46
Hello.
I think you can have a setup with a "front nginx" on another vm than the one running the docker compose joplin only file.
You should expose the port on the docker compise file as explained here.
You can contact me with one of this methods to go further if needed.
Thank you! I haven't been able to configure it properly so I opened a discussion on github
Thanks!
gri38
48
Hello !
A small release V2.2.3.
It fixes 2 bugs:
- the date of last synchro was UTC, now it's expessed in your timezone.
- The paragraphs in note view had a too big line-height. Now paragraphs are more compact (normal).
gri38
49
Hello.
A small release V2.3.0 which brings webdav synch target.
gri38
50
Hi there.
It's been a long time: a small release that brings the search for notes:
V2.4.0
- Press f key, or click magnifying glass icon
- Search syntax: documented here or here.
