Joplin-vieweb: a simple web viewer/editor for Joplin notes
great idea
New release
V1.13 of joplin-vieweb.
  • Notes history: list of the latest notes consulted, to be able to open them quickly, or pin them
    demo_joplin_notes_history
  • Tabs in notes (not displayed in joplin applications). Syntax here.
Small ENH
  • Login screen "theme" in joplin-vieweb site flavor
  • In note edition: when title gets focus: select all.
Upgrade
  • Upgrade procedure
    WARNING:
    Don't forget to add the max history depth in settings.py:
JOPLIN_NOTES_HISTORY_DEPTH = 10
Bug / ENH fixes
  • Tables are now rendered in note view
  • empty tag are not added
  • support mardown highlight with == syntax ==
  • clicking on a header on note TOC scrolls to that header (instead of opening a new window)
  • When user confirms checkboxes changes in a note, the note is not reloaded again (avoid blinking effect).
  • Same html render in compose preview than in note view
  • scroll bars are now also thin in chrome browsers.
Other
I also document a way to autostart the app on the server (crontab starts a screen session with Joplin terminal in a tab, and django joplin-vieweb in another). I chose screen to attach to it when I want to upgrade (I'm not fond of systemd). See here.
Hello.
New release 1.14 of joplin-iueweb.
This release
is mainly for fix of a major bug:
Fix #62: notes after the hundredth are not displayed.
Feature:
  • #36: display synchro message while sync'ing:
Other bug fix:
  • #33: (technical) better synchro handling at site startup.
It seems that you are indeed planning to make a joplin web client
It's ready.
But you have to run you personal server that runs django.
Here is how I did at home.
Hello.
New version 1.15 of joplin-vieweb.
  • Code blocks are foldable:
    2021-09-11 22-46-51
  • keyboard shortcuts:
    • e to enter note edition
    • ctrl + s to save note edition
    • Escape to exit note edition
    • ↑ to go to upper notebook
    • ↓ to go to lower notebook
Here is documentation for install / upgrade.
Some bugs fixes in 1.15.4:
  • 'e' key was not working anymore in note edition (not so impactful, this letter is rarely used in most languages :wink: )
  • table of content was below code blocks
  • first line of code blocks can't be selected
  • first header link in toc cannot be clicked
Hello all!
What a great project! Thank you all!
Though, are there any docker images available with joplin-vieweb?
If not I'd like to help making it happen, I can help with the dockerfile and testing, but django stuff is not my thing.
And to make things easier I think that for it to happen the joplinweb/settings.py would need to be edited to get parameters from environment variables.
Hello.
Thank you.
Great news that you'd like to contribute.
On my part, I have a docker training this year with my society :wink: but not so soon.
I'll change the settings to be used as env variables on a dedicated branch on github and let you know so you can play with it. I'll try to do that this week end...
Hello.
I don't know how to send you private message: it seems I cannot through this discourse.
Please contact me through the github project, then we'll be able to exchange by mail.
In the meanwhile, I've created a "docker" branch on the github project, and I moved all variables from django settings file to OS env variable.
Here they are:
"env": {
"JOPLIN_SERVER_URL": "http://127.0.0.1",
"JOPLIN_SERVER_PORT" : "41184",
"JOPLIN_SERVER_TOKEN" : "c0e4381fdb72159d513e0be72d14aec3b04a2ca62b2c60efcd2c365e6ff92869c439a053c57c805af913198ebabffd47f7b961aec8b4295fe508ed1533e21d20",
"JOPLIN_LOGIN_REQUIRED" : "True",
"JOPLIN_RESSOURCES_PATH" : "C:\Users\frguni0\.config\joplin-desktop\resources",
"JOPLIN_SYNC_PERIOD_S" : "86400",
"JOPLIN_SYNC_INFO_FILE" : "C:\Users\frguni0\.config\joplin-desktop\resources\joplin_vieweb_sync_info",
"JOPLIN_NOTES_HISTORY_DEPTH" : "10"
  • JOPLIN_LOGIN_REQUIRED: don't set it to skip authentication requirement, set it to "True" to enable.
  • JOPLIN_SYNC_PERIOD_S: don't set it to disable sync
Hi, busy WE.
Thanks for that I'll look into it asap and will ping you in github.
New version with hyperlink preview
Hello.
New version 1.16.1 of joplin-vieweb:
Hyperlink preview on mouse hover:
2022-02-08 10-31-54
I'm very excited for this project because it's exactly what i'm missing for Joplin. Have you considered a more modern frontend, like a single-page-application? I peeked into the source code and saw a lot of script tags, globals and jQuery. If you're interested, i'd love to help out with the frontend in particular - but i don't know anything about Python yet.
Hello.
I agree with yoo about front end technology.
I started this project as a quick try to see if I can provide a web view of my notes.
It took one-week end to have the listing of notebook and notes and to display them. And I did with "direct javascript, jquery...")
My wish was to learn and build on Vuejs, but I never took the time... and now I have it all in jquery, and I agree it's a lot of dom manipulation, not so easy to write an maintain code.
Maybe one day I'll restart, but it's a hard period for me at work, and I have no time for a while.
However, if you would start a branch with vuejs, or react or... I'll be happy to do the back part, since it's quite easy: almost everything is already done by joplin terminal, and the remining in python is quite straightforward.
So... if you start something in orange :wink: we can work together with front / back
That sounds exiting! I'll get on it, i'll figure out how to get the backend running :slight_smile:
Read the end of readme. I did it 2 days ago for a computer change. I work finall yon windows, but reading the script setup_dev_env.sh is quite straigthforward. If you need help or have questions: let's continue on github project discussion
FYI I am working on delivering docker images so the deployment is done with docker-compose.
Work is ongoing.
Hello !
It's been a long time, because "I learned Docker" (and the application to joplin-vieweb hurt a bit :wink: )
So... I'm happy to deliver joplin-vieweb as docker images.
The objective was to drastically simplify the install procedure, and now it's:
sudo docker-compose up
(After 2 or 3 settings :slight_smile: )
The new project is now here on github.
Don't hesitate to give feedbacks, I would appreciate, even if it's about bugs.
Hello.
Some new features for joplin-vieweb.
  • v2.0.3 brings the logout feature
  • v2.1.0 brings the syncho with joplin server.
  • And today v2.2.0 brings KaTeX rendering. Don't hesitate to give feedback on it.
I think in order to not mix up the two things, you should call it KaTeX rendering and not LaTeX rendering...or just TeX? What do you think?
Best regards
