"Tile-view" plugin for Joplin
Hi there!
I would really appreciate it if we could have a tile view of folders and notes, similar in Microsoft Windows. The home page is icons of folders, and when you tap at folder, it would open with its subfolders and notes.
At the moment, we only have a tree-view, which can be quite inconvenient if there are a lot of folders and notes. A tile view would make it much easier to navigate and organize our notes.
Thank you for your consideration!
this is indeed useful. it will also help Joplin users to easily find a note if they are not sure about the title as it will show more of the note body or images.
many of the new note taking apps like Keep, Notion, Obsidian have this look by default.
And Zoho Notebook too. In my opinion, it is implemented most productively there.
I hope Joplin gets the tile view option soon to keep it competitive and current.
Thank you for your support. I hope more users will be interested in this function.
Isn't it what the Note List Preview plugin does? Joplin Plugins - Note list (Preview)
@laurent I think author means alternatively showing notebooks and notes in them similar to Windows Explorer.
It would be cool if such view could be opened via keyboard shortcut to search notes when you don't really recall the exact note name, or when you want to create a note in a specific notebook, but don't recall the exact notebook name.
Here is related topic (unfortunately closed due inactivity):
@executed yes, this is exactly what I mean. In android app navigation is more difficult that in desktop app, thatswhy this plugin is prefer for android, I think.
Linking a relevant discussion that should have been a reply to the above, which is in the correct category, instead: Notes feed?
A note using the Note Overview plugin as the home note through either the Home Note plugin or Resume Note plugin might work as a workaround.
