joplin 2.8.8( perform like this since some versions ago)
file system sync. with another file sync software
windows 11 OS
After a few hours inactive in backstage. Joplin will start with about ten second stuck, and sync status on the buttom will keep doing sync. however, it does not actually sync anything, no file transfer infomation is shown (after i kill joplin and restart it sync will sync correctly).
Is there any topic about this before? i have met this problem since some versions ago.
The risk does exist if you handle the lock files manually. I once got conflicts after deleting the lock files, but the conflicts are easier to resolve than the never ending sync.
