Joplin on USB
Hey,
Would someone help me with setting up a pendrive with Joplin on it? I would like to have a joplin that would work on any PC with Windows after I plug it in. It is imperative for it to store the notes on the stick and not leaving any data on the local systems. If it would be possible to sync it with dropbox, it would be even better.
I failed to this by copping a folder with joplin from my computer.
So, how do I achieve this?
You are looking for the portable version, linked on this site: Joplin - an open source note taking and to-do application with synchronisation capabilities
Or directly download it from here: https://github.com/laurent22/joplin/releases/download/v2.8.8/JoplinPortable.exe
It will run from where you save it.
Enjoy!
Thank you
