Joplin not opening printer
3.2.13 (prod win 32)
When I use File Print on a note, printer does not open.
Windows 11, ver 24H2
Printer works for other app, e.g. Google Mail
Thank you for reporting this!
Does ctrl-p -> :exportPdf work? If not, does disabling all plugins (if any) help?
After disabling all plugins, printing worked, and after re-enabling it continues to work so thanks.
FY: Ctrl-P is listed as disabled in shortcuts; when tried, a pop up box appears with this: "Type a note title or part of its content to jump to it. Or type # followed by a tag name, or @ followed by a notebook name. Or type : to search for commands."
Clarification: Typing :exportPdf after pressing ctrl-p is one way to run the "Export PDF" command (which shares some code with file > print). The goal of this was to help determine wither the issue was with Joplin's note exporter or with the print dialog.
Joplin 3.3.9 (prod, win32)
Device: win32, x64
Client ID: ec934152e8ab441e8d1466e69798f9ff
Alternative instance ID: -
Revision: 5d0fa75
Ctrl-P brings up the box and when I enter the :exportPdf it brings up a Windows File Manger window where I can specify a file name, but nothing happens after that - i.e., no PDF file is saved.
Printing does not work at all anymore. I tried disabling all Plugins and that didn't help. I decided to only re-enable the Backup, and that also did not help. Printing used to work. Not sure when it got broken as I hardly ever print anything.
Hope you can fix this!
Marian
P.S. Still using Windows 10
Thank you for checking!
I've opened a pull request that should fix this:
the export PDF shows the window, and takes a file name but then does not save anything. Also, yesterday's report of success, is now followed by failure, again. All plug-in off, rebooted No print, no PDF export....Something with this set up, as I can print same file from iPhone (tho without formatting)
You are correct! I have the same problem as of today with version 3.3.10. Won't print from either of two computers; confirmed that these machines do not have a problem printing otherwise.
Joplin's wonderful, as are those who maintain and improve it. Will donate again with no regrets.
Terry Elrod
Me too but under LINUX only (not under Windows). 3.3.10.
Joplin 3.3.12 (prod, win32) (Windows 10)
Device: win32, AMD Ryzen 7 5700U with Radeon Graphics
Revision: 4d790b6
Backup: 1.4.3
Just allowed Joplin to be updated and the print and export PDF features are working again. Thank you!
Marian
Yes and no... For me it "works" under windows but it take such a long time now....
Fixed for me with ver 3.3.12
