Joplin layout and emojis
How to make joplin display emojis under Ubuntu Linux?
How to make it look nicer its ugly?
How ugly? Can we see a screenshot?
My OS is:
Kernel: 5.3.0-40-generic x86_64 bits: 64
Desktop: Xfce 4.14.1 Distro: Ubuntu 19.10 (Eoan Ermine)
Below next to Joplin I'm including few other text apps like:
gedit, leafpad, remarkable, mousepad, notes.
So once again: what do I need to do in order to make Joplin nicely display emojis all over the app?
Thank you very much
Szymon
@Szymon This solution worked for me.
@johano thank you for your answer.
I can see you have beautiful emojis on your side :wink: lucky you
Unfortunately nothing changed for me despite the fact I followed the article.
I installed NOTABLE and I see the same crap. Only UNCOLOURED renders emojis properly.
NOTABLE
UNCOLORED
Sorry it didn’t work for you. Are you able to see the Noto Color Emoji font in the font menu on other programs, e.g. LibreOffice Writer?
I’m using Solus here, but as far as I remember in Ubuntu the user added fonts live in ~/.local/share/fonts , although it would surprise me if a font added to ~/fonts - as the described in the web article - didn’t work also.
Hope you find solution
  1. I reinstalled Ubuntu Gnome 19.10 to:
    Desktop: Gnome 3.30.2 Distro: Zorin OS 15.2
  2. I then installed gtk,glib,pango,libcairo and the following macos themes:
sh
Summary
wget -O mac-fonts.zip http://drive.noobslab.com/data/Mac/macfonts.zip
sudo unzip mac-fonts.zip -d /usr/share/fonts; rm mac-fonts.zip
sudo fc-cache -f -v
sudo add-apt-repository ppa:noobslab/macbuntu
sudo apt-get update
sudo apt-get install macbuntu-os-icons-v1804
sudo apt-get install macbuntu-os-ithemes-v1804
sudo apt-get update
sudo apt-get install slingscold
sudo apt-get update
sudo apt-get install albert
sudo apt-get update
sudo apt-get install macbuntu-os-plank-theme-v1804
and the entire OS now looks just amazing
Glad you got sorted! Looks good, and useful info for others :smile:
