Joplin-Folder on Android phones
If you are not sure if it's a bug or not, PLEASE POST ON GITHUB ANYWAY.
If you can also please provide a log, as described here: How to enable debugging | Joplin
This is no version-related question. Anyway:
Android phone running e/OS 1.14-20230816320942 Joplin 2.12.2
Android phone runnung an outdated Android 10, Joplin 2.12.1
Linux Mint 21.2 Joplin latest version
All of this works well with Dropbox -Synch.
Question: is it possible to configure the memory (in this case an SD-card where the Joplin-Synch Folder is placed on an Android phone? In my hands it ist always in the main memory.
Best regards
Bernd
