The last version working is Joplin 1.3.18 (prod, win32).
All following versions just hang in the taskmanager with 0 % CPU usage.
I even installed a fresh Win10 32bit. Not working either.
What can I do?
Thank you!
What can I do?
Thank you!
If I remember correctly from another thread or issue, win 32 bit is no longer supported by the new electron version witch Joplin is using.
