Hello, I can see attachments in some notes and only links in some, how can I make all notes see attachments? I don't know how to switch which editor I use. But since everything is markdown enabled, I assume I'm using markdown. I don't know if that was always the case. I've been using Joplin for a long time.
The image is visible on the two tablets with older Android versions and the PC.
All settings on the devices are identical
