Hey, I am Vishal, a 4th-year Software Engineering Student at VIT University. I have good knowledge of Web development. I have worked on many projects using React Js, Javascript, Node js, Python, C++. I am also a good competitive programmer. This is my first time in open source and I am willing to learn as much as I can and contribute back to the community.
Github profile link: Here
Hi there,
Welcome to the community.
Would you mind sharing which bug you are going to work / you are working on?
thx & goog luck
I haven't yet decided. I'm new to open source, so to work on an issue first I have to make sure its assigned to me right?
It is up to you to chose a issue and try to fix it, we won't assign anything.
Just say in the issue that you are going to work on it.
Some Issues are labelled with good first issue
Hi there,
you are doing?
Are you getting along well?
Any help required on how to read Joplin's codebase and how to fix an issue easily?
good luck
