Insert (Create) Today's Node (Note)
There's a feature in an application called CherryTree where if you press F8 the program creates a day's note (ex: 08 Sat) inside a parent notebook for month (ex: May) inside a parent notebook for year (ex: 2021). If the note is already created pressing F8 makes the program go to that note.
This feature is really useful when writing a journal and searching information by dates.
And i would love to see an implementation for that feature, also i'm not sure if the plugin API for Joplin is capable of doing that, if you know please tell me
Yes the Plugin API can handel this.
  • Create folder
  • Create notes
  • Bind commands to shortcuts
Hi @97997
I would also be interested in such a feature. I have a journal folder in which I have the notes of each day in the format 2021-05-09
It would be ideal also to have the possibility to go back to the note of the day with a keyboard shortcut.
If you had the desire and ability to make such a plugin it would be very interesting.
Great idea!
Maybe consider making the structure configurable. For example, I like having a weekly note inside a year folder. Others again might have different schemes.
