Images not loading
Android
Dropbox
Images in some notes won't load.
This seems to happen randomly, AFAIK.
What exactly do the icons mean?
The download icons usually mean that the images are not yet downloaded from the sync target or that the images are in the process of being decrypted.
The "Attachment download behavior" setting in configuration > synchronization > advanced may be relevant here. It adjusts when/if images are downloaded. For example, if set to "Manual", Joplin waits until the "download" icons are clicked to download the associated resources.
Thanks, I believe I did check that before. It's already set to "Always". Might be an issue with my mobile data. Coverage is pretty poor here.
Will continue testing for now!
