Hello all, is it possible to reorder Notebooks like notes?
Not currently (I think?), it sorts alphabetically. I did make a hack to create pseudo ordering quite a while ago... Share your CSS - #296 by Daeraxa
@markusgod, select your Notebook in the Notebook List, and from the context menu select Toggle own sort order
That just allows a selected notebook to save its own sorting criteria of the notes within it, it doesn't change the order of the notebook itself.
Ah of course,it was custom Notebook and not Notes order the OP wanted.
Thanks. This is viable, but a bit too cumbersome for me. I guess I'll stay with Obsidian for the time being.
When I discovered Joplin I was blown away how good sync worked.
