Hello, is there a way to link another note and to put this in a href element ?
I can write the path to local files to execute in href element but how link to other note in html element to open a new note when i click on html button for example ?
Thank you and …really a well done application this joplin…
Note that links work in both HTML and Markdown code. So you can have:
[Link to my note](:/0b0d62d15e60409dac34f354b6e9e839)
or:
<a href=":/0b0d62d15e60409dac34f354b6e9e839">Link to my note</a>
in html mode
<td align="left"> <a href=":/80743ebbae814b828d84a354d9996bbd">Link to my note</a> </td>
I get an error
the note ID is correct
this is the joplin version I use (portable on pendrive)
to link other note in html this call works but doesn’t on android
<td nowrap>
<a href="#" onclick="ipcProxySendToHost("joplin://80743ebbae814b828d84a354d9996bbd"); return false;" type="">Link to my note</a>
</td>
