Android
Joplin 3.7.21 (prod, linux)
Appareil : linux, Intel(R) Core(TM) i5-7Y57 CPU @ 1.20GHz
ID client : 95c035210ae047c08e323f07176b0548
Version de Synchro : 3
Version du profil : 54
Trousseau supporté : Non
ID d'instance alternatif : alt1
Cible de synchronisation : Nextcloud
Éditeur : Rich Text
Backup: 1.5.1
Conflict Resolution: 1.2.3
Freehand Drawing: 4.3.0
Nextcloud
Hi
I must say, I have always been confused about the expected workflow on resolving conflicts on Joplin Mobile. On desktop, there's the Conflict resolution plugin so that's easy.
But on mobile, that plugin isn't available. There's another one "Diff view" but it's unclear what the workflow is. Once I've fixed the differences, what do I do? The note stays in "Conflicts" notebook.
