How do I reset Joplin!?
Client ID: 40cbac6413c44003a8ad4c19066aa9f5
Keychain Supported: No
Backup: 1.4.2
Freehand Drawing: 2.14.0
Nextcloud
I am trying to completely reset Joplin.
  • I've tried to delete ALL files on my computer and phone
  • I've turned off sync
  • I've tried to Re-upload data to sync target
  • I've tried to Delete local data and re-download from sync target
    I only have 1 note called testing
    I keep getting a sync error. I just want to completely start over. For some reason it seems to try to sync files after I've tried to delete everything.
@JoplinMe2 welcome to the forum.
If you wish to remove ALL your local data and reset Joplin as if it was just installed for the first time, delete / move / rename the folder ~/.config/joplin-desktop
