How can I search inside a note on Android?
I saw this: https://github.com/laurent22/joplin/issues/382
but I can find no way to search inside the note on Android (version 1.0.333).
How do I do it ?
Will it be helpful if I open another issue regarding this since it doesn’t appear to be addressed ?
filed a bug on github since no answer was forthcoming
disappointed
About what? Anyway, since I wrote this, there is now a way to search. You have to click the edit button for the note and then there will be a search button. Very unintuitive but that's what we're stuck with
Please stop opening ancient threads that may no longer be relevant, especially if you don't have anything constructive to add. Please just open a new thread if there isn't a recent one about the thing you are asking about.
