Hi there,
I am new to Joplin, I have been trying a number of different bits of software to capture my notes. I am primarily after security, so encryption is important to me. I would like to use Joplin on Windows 10, Linux and Android.
I own a Synology NAS, and I have set up Synchronisation via File System. So any changes in Joplin, the files are then uploaded to the NAS via Synology client software (Synology Drive Client) which watches the filesystem for changes. I dual boot between windows and linux and then, in theory, I can continue using Joplin with the latest changes. It seems to be working so far for Windows and Linux.
Is there a way to integrate android into the same system? I did try Webdav and I could get it to work for windows but I was having issues with mobile. Is there are way to use filesystem with android?
I apologise if I have missed something, I am going a little 'notes' blind this week, trying lots of different ones!!
Any tips gratefully received! Thanks.
