I'm really happy to have gotten Joplin to sync between Windows and Android devices using the WebDAV features built into Microsoft IIS. After trying to sync via filesystem and OneDrive with various problems, I think using IIS will work really well. Filesystem was working well until I started clipping webpages and my note collection exceeded 10,000 items. At that point, the Windows clients still worked well, but my Android phone was very slow to sync (one item every five seconds). I also tried syncing over OneDrive but found it to be slow; I did not like the rate limiting imposed by OneDrive which interfered with the initial syncs; and I did not like having to use the Joplin encryption features that impose too much processing and storage overhead.
So, I finally got IIS working after a bit of experimentation! Right now, it's a proof of concept because it's running on my local network and it's not yet secure. I need to figure out how to make it secure so that it could potentially be exposed to the Internet, though personally, I'll probably use a VPN when accessing it over the Internet. I really appreciate not having to use Joplin's built-in encryption, and I really appreciate that the Android sync is not made very slow by having to deal with 40,000 files in two folders. I don't know if it's the Android filesystem (on my Samsung Galaxy S24 Ultra) or the way that Joplin interacts with the filesystem that makes it unacceptably slow when dealing with large collections of notes.
I'll perfect the IIS configuration and post simple instructions in the future.
Also, in the sync documentation, it says that nginx is known to work for syncing notes. I'm guessing that's probably true, but it's not easy to get setup unless you're a software developer with particular build experience. Basically, not easy to get to nginx to work out-of-the-box, and probably impossible for anyone without some serious computer knowledge. It was too complicated for me.
