When I type a proper noun not included in the spell check dictionary, it’s underlined in red as a spelling error. After adding the name to the dictionary with the correct capitalisation, I would expect spell check to suggest it when I type the name again in lowercase.
For example, I type "Azathoth," which is underlined as a spelling error. I then add "Azathoth" to the dictionary with the correct capitalisation. However, if I later type "azathoth" in lowercase, the spell check does not suggest "Azathoth" as a correction.
Would it be possible to add this functionality as a feature?
Thanks in advance,
Jason
