Joplin should do the “heavy lifting” when a hyperlink is created.
For example:
- Space characters in URLs should automatically be replaced by the ‘+’ character.
- Local filesystem links should automatically prepend “file://” to the supplied pathname.
- Local filesystem links should automatically fill the “display name” of the link (the contents of the “[]”) with the filename at the end of the supplied pathname.
There may be other nice things - including additional special-character escaping - that Joplin could automatically do for the user when creating hyperlinks.
For example: I want to link “/Volumes/My Drive/foo/bar/hello world.txt” in a note, and so I paste that string into the “Insert Hyperlink” dialog box.
Upon clicking OK, the result in the note should be: [hello world](file:///Volumes/My+Drive/foo/bar/hello+world.txt)
