When I export a Notebook with several sub-notebooks.
Will this structure be retained when re-importing?
Or mus I Export notebook by notebook?
Thank you
It depends on how you export the note books
Example structure:
- Notebook 1
- Notebook Sub 1
- Notebook Sub 1.2
- Notebook Sub 2
- Notebook 2
File > Export all > JEXYes the notebook structure is retained
After the import:
- Notebook 1
- Notebook Sub 1
- Notebook Sub 1.2
- Notebook Sub 2
- Notebook 2
Notebook 1 an use Export > JEXYes the notebook structure is retained
After the import:
- Notebook 1
- Notebook Sub 1
- Notebook Sub 1.2
- Notebook Sub 2
Notebook Sub 1 an use Export > JEXYes and No, after the import the Filename of the Export is the TOP level Notebook and then all structure is retaind
After the import:
- FILENAME
- Notebook Sub 1
- Notebook Sub 1.2
I cannot say this for RAW, as I do not use this format
